AKA updated versions of ArcElite and NetHack for RISC OS. Ignoring the fact that I'm behind them (read: computer may grow tentacles and eat your house), the updates are as follows:
ArcElite- The game will now load a lot quicker on StrongARM machines, as it is now cache-friendly
- A bug has been fixed which could cause the game to crash by it drawing outside the screen bounds
- Works OK with the exisiting version of EliteExt, cheat modules, etc.
Downloads are available from
right here at Acorn Arcade, or over at
my silly website.
NetHack 3.4.1 for RISC OS release '0' (updated)
- Fresh RISC OS port of the new version (3.4.1)
- However it's still very early on in development so it may not run perfectly
- Main feature of this second release (the first being '-1') is the addition of some IBM graphics character definitions to allow the game to be played 'properly', and the fixing of a bug which caused the game to crash after the first level had been drawn
- You can download the source code now too
You can grab a copy from
my website.
AngbandWhat? How did that get here? Bah!Andrew Sidwell has (indirectly) mentioned to us that he will soon be working on an up-to-date port of
Zangband. You can also find some other
Angband ports
over here.
Thargons spotted in ASCIIville (updated) |
(17:20 4/3/2003) Jeffrey Lee (11:29 6/3/2003) Guest (11:20 23/3/2003)
John Hoare |
Message #87505, posted at 17:20, 4/3/2003 |
Unregistered user
/me will try the new Nethack port tonight :-) |
Jeffrey Lee |
Message #87506, posted at 11:29, 6/3/2003, in reply to message #87505 |
Unregistered user
For those who've downloaded release 0 before now:
I've just released a small update on my site to fix some files which got missed out of the nhdat archive. I'm blaming the program which made the archive; the wildcarded file names that were given to it should have worked OK >:(
The next release should be tested properly though ;) |
Guest |
Message #87507, posted at 11:20, 23/3/2003, in reply to message #87506 |
Unregistered user
Indeed, as well as Zangband, me and my brother intend to bring the full range of ports up-to-date. It just requires patience (compiles take a while) and a new icon for each variant. It's not really "work" as such; more like time-wasting. |
