So you want an A9home? You want to use that favourite application you bought at a recent show? But does it work? Paul Stewart, an A9home owner has set up a webpage detailing what software currently works on the A9home.
Although a lot of popular titles don't currently work, it is expected that either developers will be able to change them to work, or they will work under Aemulor, as monkeyson and myself witnessed at the recent Wakefield show.
Link: Compatibility List
A9home software compatiblity |
rich (14:38 8/6/2005) sa110_mk (16:09 8/6/2005) rich (19:08 8/6/2005) mavhc (13:45 10/6/2005) rich (09:19 12/6/2005)
Richard Goodwin |
Message #93659, posted by rich at 14:38, 8/6/2005 |
Dictator for life
If someone would produce a legit 32bit aware version of something like the EasySocket module, I could get LinkSure working. And perhaps add features to other software like update checking. Any other fairly trivial bits of software people would like to see so that they can develop/update their software? |
Paul Stewart |
Message #93660, posted by sa110_mk at 16:09, 8/6/2005, in reply to message #93659 |
Does the EasiSocket module work under Aemulator on the Iyonix? If so then I expect it will also work on the A9 with Aemulator, as I expect will most 26bit applications. |
Richard Goodwin |
Message #93661, posted by rich at 19:08, 8/6/2005, in reply to message #93660 |
Dictator for life
Possibly, but it'd be better to have a version that works out of the box, that could be distributed along with my module-dependant software :( |
Mark Scholes |
Message #93662, posted by mavhc at 13:45, 10/6/2005, in reply to message #93661 |
Reason to only use GPL etc software number 1 |
Richard Goodwin |
Message #93663, posted by rich at 09:19, 12/6/2005, in reply to message #93662 |
Dictator for life
Fine idea, so long as a GPLd version of the software exists in the first place. It's not like we've got lots of different options here. |
